Sci-Fi Starship Quarters
I am using iRay have got a couple of environments that are so dark and I can't seem to light them. The walls just seem to suck the light in like a black hole. I can put a million lumen light in and it doesn't make much difference.
This is the one I am trying at the moment.
https://www.daz3d.com/sci-fi-starship-quarters-volume-2
Are these environment really aimed at 3Delight?
  • GordigGordig Posts: 10,819
    No, it's definitely Iray, and with an HDRI and so many emissives, it's odd that it would turn out dark for you. Where are your tone mapping settings at?
  • These are the settings I am using.
    Can't preview the attachement so will roll with it and see how it turns out.
    571 x 821 - 86K
  • I took a couple of very quick (and incomplete and tiny!) renders to show the lighting. These are from the bathroom of the environment.
    The first is with the usual 3 point light set up I start with (Key 150,000 lumens, others less). The second is the same lights dialled up by a factor of 10 (making the key light 1.5 million lumens).
    You can see the brightness in the white clothing. It just doesn't seem to light up the surfaces.
    I am probabky doing something really stupid, but can't work out what it is !
    I had much the same issue with the medi lab. All the other environments I have used light up. These just seem to soak up any light I throw in there.
    https://www.daz3d.com/medi-lab
    480 x 480 - 307K
    480 x 480 - 351K
  • I spend a while just playing with the surfaces, especially the walls.
    By raising the Top Coat Weight of the walls to 1 (from zero), the Metallic Flakes Weight to 1 (from zero), the Diffuse Overlay Weight to 1 (from zero) and switching base mixing to Weighted (from PBR Metallicity/Roughness), I got to this.. but I don't really know what I am doing. I suspect these should be positive values though, from the effect. Is 1 too high?
    Something to do with the default surface settings, it seems to me.
    480 x 480 - 475K
    These are the default settings, and they're optimised for a bright cloudy outdoor scene (the default Environment light map). They tend not to work well with even well-lit interior scenes. Try turning the Shutter Speed and/or F/Stop values down and see what happens.
  • Thank you. Will give that a go.
