High resolution monitor
DrPingyDrPingy Posts: 78
Has anybody work with a 4k Monitor (3840x2160 pixels) and DAZ studio?
Is in DAZ Studio a possibility setting the size of the fonts in Tabs? I have only found color settings.
I have had a change to work with a high resolution monitor and win8.1. It is perfect!
But some programs have very small chrarcters. So you cannot read and control some buttoms.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,645
    I am no help but damned glad you pointed that out
    maybe in DS there is hope someone may know
    BUT
    Carrara and its tiny font size has been a issue for me and many others so one more reason besides price and deskspace (have dual monitors already) I will not get that 29" superHD monitor I was eyeing off at DickSmith!
  • DrPingyDrPingy Posts: 78
    Dual Monitors are a very good solution. But at home I have no place for that.
    In Blender is a very good solution for high resolution monitors. In dialog "user preferences->system" you can set a DPI value for the display. 72 DPI ist the default setting. If you set higher values all elements will bigger.
  • Gusf1Gusf1 Posts: 258
    I just got a seiki 39 " UHD TV that I use. If I were sitting at the desk, the font wouldn't be a problem. Actually, the text looks about the same size as the 27" monitor that I upgraded from.
    Gus
