rigied "outfits" or outfits with "attachments"
ok, i've decided make this after notice a really big ammount of outfits using this "daz tool", which while inside daz it's amazing, "outside is totally pointless, for what i get it is a way to "attach details like buttoms to a "place on the outfit without it get "streched" like normally could happen using the regular way, here the "inside daz
here it "outside daz
as you can see it don't work.
my questions is inside daz have "anyway to "combine" the rigied stuffs direct to the outfit??? to make then really part of the outfit???, you have any option inside daz to combine those stuffs direct to the outfit or the only way is using a "3d model editor?? to edit it externally?
inside daz have any way to 'rework it????, i means that because i would prefer avoid using a 'third part program and focus only in fixing stuffs "inside daz or unreal" rater than have to go a third program, not saying which they are bad, however i want to means which is much more easy to keep focus only on the programs you want to use than having to "use extra programs", for exemple in unreal a way to "try to fix it would be making "sockets around the "area i want then to be fixed but it would have some "issues with the buttoms moving in a weird way in the outfit, then would be good if could be possible to fix it direct in daz before exporting.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,854
    edited September 2020
    ah yes happens in iClone too if I over look any and don't fix them cheeky
    UE4 it's actually possible  to fix, albeit a pain, iClone I need to start over from DAZ
    I select all objects and unparent them from the clothing attachments then parent each to the nearest body part on the figure
    in Unreal I edit the animations moving the bits selected on the skeleton  to the right places at the beginning of the timeline and creating a keyframe
    in iClone 3DXCHANGE I am basically stuffed, cannot fix it need to start over
  • MadaMada Posts: 2,079
    A quick question - if it was a fitted figure instead of a prop would that work better? If so its then easy to actually take each button, use the transfer utility to fit it to the parent clothing item instead. That will give you a button figure fitted to the clothing. Would that make it easier in Unreal?
    Post edited by Mada on
  • EllessarrEllessarr Posts: 1,395
    wow that is why i love peoples here, perfect call, it really worked the "only possible issue" would be which the "stuffs" now will "deform" but unless the character is a "huge deformed character it honestly speaking is not a big deal compared to the other option.
    here a image
    one of then got really, really deformed but well, for animation and game unless you gona do a super closeup and aiming for max realism it not a big deal
    it gonna be a little pain in some outfits cases which have like 10+ attachments to have to work on each one lol.
    Post edited by Ellessarr on
  • LeanaLeana Posts: 13,682
    Maybe try exporting all of them together as obj then rigging the resulting obj?
    Glad that worked :)
    You will get the best results by using the transfer utility, select the clothing item as the source and the button as the target, make sure morph targets is ticked and select shaping and pose as well as in the image. That will give the you the best results and least distortion for morphs that's already in the outfit.
    470 x 671 - 88K
    Mada said:
    Glad that worked :)
    interesting i will test it later, now it's already almost morning here and as a "good internet vampire" i need to rest now you know "sun" is bad for us :D, thanks.
