Poser faces applied to Genesis or M4 V4
mjordy59mjordy59 Posts: 66
I used to have Poser Pro(P7) but uninstalled it and only left the runtime content folders to use my newly installed Daz Studio 4.6 Pro to access them. I have no problem loading poser figures:Simon,Hiro,etc into Daz Studio, and all the old poser files show in the content Library
in Daz. Also most poser clothing loads onto Genesis,or V4,M4,with not problem,and with little tweaking.
The only problem I've found is that when I want to load any Poser faces,Morphs they don't load at all. And I don't get any eror messages,is as if the faces files are non existing,even though the thumbnails show up in the Content library pane in Daz.
Is there a way of tweaking the faces files to load into Daz?
  • Richard HaseltineRichard Haseltine Posts: 111,721
    If they are trying to load new morphs from .pmd files that may well be failing - check the log file (Help>Troubleshooting>View Log) after trying to apply a pose and if there's an error message post it here please.
  • mjordy59mjordy59 Posts: 66
    edited July 2014
    Thanks Richard for your advice here4 it goes:
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.LipUpFull.pz2 on line 80 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.LipLowFull.pz2 on line 81 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.LipLowOut.pz2 on line 82 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.MouthSmall.pz2 on line 83 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.JawFull.pz2 on line 84 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.JawSmall.pz2 on line 85 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.ChinCleft.pz2 on line 86 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.ChinSmall.pz2 on line 87 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.OpenMouth.pz2 on line 88 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Warning: Could not find file :Runtime:libraries:!DAZ:Victoria 3:Head:ChanVis:Unhide.MouthYell.pz2 on line 90 in C:/Program Files/Smith Micro/Poser Pro/Poser/runtime/libraries/Face/OOT Asian Influence/Asian Influence 03 INJ.fc2
    Time to load file: 2063.17 ms
    Imported: Asian Influence 03 INJ.fc2
    Building Scene...
    File loaded in 0 min 2.3 sec.
    Loaded file: Asian Influence 03 INJ.fc2
    Importing File...
    Importing Uhura.fc2 ...
    Time to load file: 45.752 ms
    Imported: Uhura.fc2
    Building Scene...
    File loaded in 0 min 0.4 sec.
    Loaded file: Uhura.fc2
    Importing File...
    Importing Darley Head INJ.pz2 ...
    I did browse to the files locations and they are there!.
    somebody else where suggested to renaming the "fc"2 to 'pzr" but it doesn't make any difference.
    Post edited by mjordy59 on
    Do you have the OOT Asian Influence for Victoria 3 morph set? That appears to be what it is looking for?
    Yes, I have all the V3 morphs,including the OOT for Asian influence for V3 morph set.. So I'm stumped.
    Looking at the list again, I see that you have your content in the application folder - if this is Windows Vista or later that may well be the root of the problem, with recent versions you should have data outside the application folder (and program Files generally).
    edited July 2014
    Thanks for your reply again.
    No actually i have Windows XP ,SP3,4 Gig Mem. The confusing thing is that even the log show some of the faces load ,but it doesn't
    change the facial features in Genesis at all! see the log list below and the pic.
    Importing File...
    Importing Kirk.fc2 ...
    Time to load file: 53.9528 ms
    Imported: Kirk.fc2
    Building Scene...
    File loaded in 0 min 0.3 sec.
    Loaded file: Kirk.fc2
    So maybe it might be an incompatibility with Genesis?
    The faces were made for M3 but still they don't affect the morph at all!
    971 x 694 - 259K
    971 x 694 - 225K
  • ByrdieByrdie Posts: 1,783
    You have to transfer morphs for figures like M3 and M4 to Genesis first, using a program like GenX2 or the more complicated but free method described in several forum threads here. The .fc2 files are Poser face files and Genesis doesn't take them straight out of the box. But if you're trying to use them on the original M3 and M4 figures, they should not need converting.
    edited July 2014
    Thanks guys for the advice,i'll give those suggestions a try,and try a little tweaking from other suggestions from other Poser forums as well.
