Is there a way to fast-sellect the hip bone?
handel_035c4ce6
I mean douible click selects the figure itself but I still have to go to the scene tab, expand the figure and manually select the hip and with the quantity of fine tuning the custom poses require it is a real... well, you know:-)
So is there a hot key to sellect directly the hip?
Post edited by handel_035c4ce6 on
You could use a script to get the current figure (if any), find its first first level node child, and select that - then assign it to a button or shortcut.
Use the Active Pose Tool and click on the hip region to select it. If you miss it at first try and get the pelvis eg... try again.
