Transfer Utility Problem
Hi all,
I try to apply a shirt, exported from marvelous designer as obj, but after I run transfer utility the shirt is rotated.
Have I missed to apply a setting before? I just imported it and positioned it a little so that it fits to the model.
Any idea what could be causing this issue?
  • LeanaLeana Posts: 13,696
    edited September 2020
    The mesh you rig has to be in the right position on load, you can't reposition it before using transfer utility.
    So you need to export your repositioned mesh as obj and then load and rig that version.
    Edit: for the record, you're not allowed to post images with textured nude figures. Please set the viewport to smooth shaded before taking screenshots.
    Post edited by Leana on
  • It sounds, without having seen the image, as if you may have the wrong preset in the OBJ import dialogue. If you were working around an exported Genesis make sure you use the same preset in both directions, if you modelled freehand then try the Daz Studio preset and if that's off try the Modo preset.
  • Great, I will try this. Thanks you both for your help.
