dForce and Memorized Pose Issue
I'm having trouble with dForce sims. I'm using Start Bones From Memorized Pose, but the memorized pose it starts from is nothing like the pose I set at frame 0 using Edit>Figure>Memorize>Memorize Figure Pose. Is there another, dForce-specific pose memorization menu item I'm missing? How do I best clear this other pose and replace it?
Thanks in advance for the help.
-DA
  • That should work, as long as none of the posing controls used were mis-typed (not set as Modifier/Pose in Parameter Settings, from the gear icon on the slider).
  • digitaladipositydigitaladiposity Posts: 34
    edited September 2020
    I've never modified the Parameter Settings for posing controls, but I'll check through the Currently Used controls and see if there's anything like that. Thanks.
    2:55pm, all of the currently used posing controls have the proper type selected.
    Post edited by digitaladiposity on
  • Does the pose save correctfly as a Pose Preset? Does it work if you use Edit>Figure>Bake to Transforms?
    I'll have to test that and get back to you soon. Thank you for your attention to this matter.
  • It saves correctly as a Pose Preset, but when loaded it still snaps upward in Y at the start of simulation and the expression is lost. When I used Bake to Transforms, the memorized pose no longer pops off the ground when starting the sim, but it still loses the expression.
  • OK, if the expressions are correctly set as Modifier/Pose then I don't know what to suggest.
    Thanks for the suggestions. Reluctantly, I'll need to salvage an earlier version of the character that doesn't have this memorized pose issue. Hopefully, I won't have to go far back.
