Shape control on the shape tab for a Morph
Marmalade Boy
Hi there,
In previous versions of Daz3d, you were able to move a morph from the parameters tab (located under the morph loader section) to the shape tab under actor/full body (or what ever) via the Property Editor.
As this editor is no longer available, can someone advise on how to do this? My goal is to move my morph from the parameters tab to the shape tab. I am not sure if this is now done via the Property Hierarchy (which is completely confusing by the way); is there a tutorial on this? i couldn't find one. This new PH looks like a hot mess.
644 x 838 - 68K
1610 x 614 - 443K
Post edited by Marmalade Boy on
It is Now done with the Morphs Property Editor, the Gear, you can assign the morph to most areas...
Hi Jaderail,
Thanks for the fast reply...unfortunately, that did not work for me. I am not sure if it's because of the version I am using (4.6.2.118) but it didn't. While trying to do it your way. I found a setting called property group; which was the setting I had originally used in previous versions.
It worked like a dream. It was quick and very simple. I have no idea why I couldn't do it your way. Thanks again for your help!!
You hit it on the Head, Versions do things just a bit different. I'm using DS 4.6.3.52.
