How do I rotate several objects as a group?
srieschsriesch Posts: 4,243
edited July 2014 in Bryce Discussion
Nevermind, I somehow had two of the objects grouped with a completely different object with a similar name instead of with the object I thought they were grouped with. After ungrouping and regrouping everything correctly, it works as expected.
ORIGINAL BAD QUESTION:
I have three objects grouped together to make a single object, and wish to rotate the entire group as one unit. How do I do this? Currently, Bryce insists on rotating each individual object around it's own center, rather than the group around the group's center, so the group splits apart and all the pieces are moved around during rotation.
Post edited by sriesch on
  • GussNemoGussNemo Posts: 1,855
    Nice to hear you figured it out.
    Have you ever realised that the speed with which you work out the solution to the problem is sometimes inversely proportional to the time it takes you to press the submit post button? :coolsmile:
    It is amazing how much knowledge can be released by pressing that button. I am sure it hides in there in order to try and make people look stupid. :roll:
  • srieschsriesch Posts: 4,243
    So true. Same with spelling mistakes. Type something up, reread it to make sure it makes sense... wait for it... fine, hit "Submit Post" and BAM! instantly I see two misspelled words and a missing comma or something.
  • HoroHoro Posts: 11,742
    Oh yes. I write my comments outside and read it several times before copying it into the form, check the spelling, hit submit, read it, and start editing ...
    ...and here I thought I was the only one with that problem.
