Problems with Lipstick colour
Harbadix
Hi, I'm having problems with (some) lipstick colours in iRay. There is the colour in the shader button image, the colur in the workspace and then the rendered colour. The issue I am having is the iRay rendered colour is coming way too dark and not a true to what it should look like (see example) I know the rendered colours arent the same as the preview colours in the workspare but if I apply a red lipstick I would expect to see a red lipstick.
In 3delight rendering I used to just adjust the surfaces parameters to get the perfect shade I am after but in in iRay nothing I shange in the colours is making any difference. I am still learning about iRay so am sure I'm doing something wrong but surly the one click appliers from the materials menue should be closer to what I am getting?
In the example below, the far left is the rendered colour, the right is the menue colour and the middle is the preview colour
Did you ever discover a solution?
If not a link to the actual set for which you are/were having these issues with would be helpful. Without being able to check settings it's rather difficult to guess what the problem is.
