Anatomy Rendering Error (NSFW)
Can anyone help me figure out why this is happening? Genesis 8/Victoria 8 with Genesis8FemaleAnatomicalElements. No matter what skin I apply, it doesn't work. Even using SkinBuilder doesn't correct the problem. The genital mesh also appears to not be connecting properly. Using Daz Studio Pro 4.12.1.118 64 bit. NVidia GTX 2070. Everything was working correctly than mysteriously just stopped. Video card drivers are up to date.
Mod edit:- Image removed
Post edited by Chohole on
You need to check the terms of service about posting images.
With no pics, wild guesses ;-)
Some presets are the "H" type, need to select the main figure, then they will work on the elements.
I don't have SkinBuilder.
Any geograft mesh will only "fit to" properly on the figure it was made from. BUT if you have selected the content creation tools [i.e. the geometry editor brush] then they are not activated. Use the pointer selection tool.
