Parameter setting favorites
I would like to "default favorite" some sliders, for example expressions, so can find them easier when creating a new scene. Is there a way to do so? At least I can not find one.
    1. Load your base figure or the developer version to an empty scene. ("Genesis 8 Basic Female/Male" or "Genesis 8 Female/Male Dev Load")
    2. Select the figure
    3. Check the expressions or morphs you want as Favorite
    4. Memorize the figure (Found in Parameters-Tab, drop down menu)
    5. File->Save As->Support Asset->Save Modified Assets
  • TaozTaoz Posts: 10,370
    edited September 2020
    Click the Heart on the slider to make it a favorite, and then select "Favorites" to show these sliders only.
    555 x 279 - 24K
    Post edited by Taoz on
  • Set the character up the way you want it, then save a Character preset and use that to load the figure. I wouldn't advise modifying the assets as they will be replaced by any future update.
    With a character preset, the favorite-status can only be found on characters that were made with that preset, saving Modified Assets brings the status to all characters (with the same base figure) including ones in previously saved scenes.
