Can I copy shape morph properties from one point on timeline to another by using Edit Mode?
iSeeThis
My job is about to morph a G8M from a character to another ie; human to devil, young to old etc. Sometimes I've tried to find a way to copy a group of shape parameters at frame 34 to frame 15. I enter Edit Mode on parameter tab and select/copy/paste but fail. Nothing happen after pasting. Did I miss anything?
What are you wanting to copy? A modifier is available in all frames once present, copying settings doesn't require being in Edit mode.
Thank you very much for your kindness, Richard.
1) Supposed I have Genesis 8 Male in a scene.
2) In timeline at frame 0 I make the first keyframe.
3) At frame 100 I turn 10 Aging parameters into 100% (have 10 parameters changed)
4) If I want to copy all of those parameters onto frame 0, what shall I do?
If you expand the property list you should be able to see the keys, marquee select them, and copy, then paste at frame 0
Thank you Richard.
