Toony Cat/Toonimal Kitty errors
Using the Toonimal Kitty. Have all assets and addons. Material addons work, but Toony Cat shapes to make other animals will not work, what am I doing wrong?
  • NorthOf45NorthOf45 Posts: 5,898
    edited September 2020
    Toony Cat characters won't work with the DAZ Studio native (.duf) version of Toonimal Kitty. You need to install the Poser version of Toonimal Kitty, then load the Toony Cat.cr2 (under Figures\CDI Toonimal Morphs in the Poser formats section), then apply the characters.
    Note: there is a bug with the Rabbit character, which squashes flat in all sorts of disturbing ways. Easy fix, though. The script hides some tail sections and scales the last one used (Tail04) to 0.0 on x, y, and z to taper the remainder to a point. Something about parametric rigging does not like that, so scale it and the next section (Tail05) to 0.1% (or something > 0.0), and the rabbit will magically re-integrate. There will be a small hole at the tip of the tail, but it is not noticeable with very small scale values.
    Post edited by NorthOf45 on
