D|S not importing .obj
In the last few months D|S has started having problems importing recently created .obj files. When I import everything seams normal, I get no error message, but nothing loads. It's not 100%, some will import, most don't. I'll have a model that D|S will import but if I make changes in my modeling app (wings3d) and export it again suddenly Daz won't import it.
I haven't updated Wings3D or D|S recently, updating and rolling back graphics drivers has had no effect. Poser will import them just fine, but it's a real pain to import them in Poser and save them as a prop just so I can get them into D|S.
I'm at a loss as to why this just started.
Any help would be great!
  • Some obj models made for Poser have an extremely small scale.  DazStudio does load them,  and if the obj is in the scene tab after import,  you have a couple options.
    Select the model from the scene tree,  and click scale. The default is 100%  change that number to 24,000%
    The other option is at import  Daz Studio gives you the option to import with poser scale and does the conversion during import.
  • EthinEthin Posts: 1,347
    These are models I've made myself and are scaled to D|S defult import/export scale. After importing the viewport and scene tab both show that nothing was imported.
  • lilweeplilweep Posts: 2,883
    I have not had a problem importing obj recently and i have probably imported several hundred from various sources within the last three months.  Obj is the only reliable file format.
    I wonder if there could be something weird with your export settings in Wings.  Does it load into other software, e.g., Blender?
    I recently discovered you can just mass drag and drop obj into the viewport also - which speeds up making prop/figure presets.
  • can you share the file?, or at least post an screenshot in wings about the file?
    ... and now it's fixed!!?
    I guess it was the graphics driver after all, not sure why it took a day to take effect. The .obj's that would not import before still wont but new export of the same models will now import. Wonder if it's a bad thing that I'm now running a driver from 2018.
    Sorry to bother you all for nothing, thank you anyway!
  • Good that you got it sorted out.  Obj is a reliable model format generally.
