Help to save wearable presets with attributes
meucontatovirtualmeucontatovirtual Posts: 10
edited September 2020 in Daz Studio Discussion
Hi, I would like your help! how can I save clothes (wereable presets) by putting attributes on the body (for genesis 8)?
for example: I want to save a shirt, but I want the arms (of the character, not the clothes) to be invisible under the shirt.
Post edited by meucontatovirtual on
    When you save the wearable preset there are tabs for adding pose, etc. properties for the selected figure.
  • I'm quite confused, because I've tried several options and I didn't get any results ... I select in the body G8 the icon of the parts that I want to be invisible, and to save the clothes (wearable presets), I already tried several of the options of the tabs, but nothing worked. .. I've tried to select the options that I thought were correct, I've left everything checked (as in the prints) and without results
    Would it be possible to explain a detailed step-by-step?
    1000 x 501 - 83K
    How are you setting the bones to be invisible?
  • I'm obviously not doing it right, because I don't know the procedure...
    but, I leave invisible parts in the base figure that I want to be hidden, and select these options when saving (among other attempts with different options, which also did not work)
    1104 x 547 - 145K
