Skin issue after rendering
I have just met the problem that after loading a preset scene called the Morgue, the skin color of the figures that I loaded to the scene will be altered to a uniform color, no matter what kind of scripts that I use to adjust the skin color it never really works. I also tried to use different lighting presets, it ain't work either. Is this because the lighting preset under the scene or is because sth else?
Please either crop the images higher or give the figure some pants.
This set https://www.daz3d.com/the-morgue ?
What happens if you reset the Render Settings to Defaults using the button at top-right of the pane, then adjust the Tone Mapping so you can see something?
Here is the adjusted picture, same situation happens to female figures as well. All the figures present the same skin color in the left image.
I have tried to reset it as default and it gets the same result
