Little help with products poly count:
EllessarrEllessarr Posts: 1,395
edited September 2020 in The Commons
hello, guys i'm interested in buy those outfits:
https://www.daz3d.com/dforce-anubis-priest-outfit-for-genesis-8-males
https://www.daz3d.com/dforce-barbarian-queen-outfit-for-genesis-8-females
https://www.daz3d.com/dforce-jw-clothes-pack-for-genesis-8-females
https://www.daz3d.com/pilots-uniform-of-wwii
then  if anyone owns then i would love if you could provide the "vertice count" of then(polygons), to make things simple don't need to post a full info just post the "vertices numbers(remember it's about the "base numbers not the active/high resolution)
for exemple this outift:
https://www.daz3d.com/swimwear-for-genesis-3-female-s
his total vertices count(all pieces together) would be:
57.904/3.747 (active/base) for what is matter is just the vase don't need the active number then the count would be just:
https://www.daz3d.com/swimwear-for-genesis-3-female-s ;  =  3747
now if possible a more "precise number then it would be likie:
top = 1.754
bottom = 1.993
total = 3.747
you can choose or only give the "total" in case the outfit have too much parts and don't want to go to this "chore" or if not that much or you don't have a problem then post the number for each part then the total.
to ge "each part just add the part and click on it then in the panel info it will display the number for that part, you can add the full outfit then go manually clicking on each one, to give the full numbers just load all the outfit and make sure nothing is selected then in the scene info will display the "total number fo all parts".
Another note i'm only interested in the "ouftit" not the "props" like weapons" you can post then too but they not be take in account for the total, in case the outfit load with the weapon then remove it and add it alone in the scene to make sure only outfit is being displayed.
then if anyone which had bought any of those outfits and can share i will be happy because i'm thiking in buy it today before the current sales end.
Post edited by Ellessarr on
  • GordigGordig Posts: 10,802
    dForce Anubis Priest Outfit
    Scene Geometry : Active / Base
    Total Vertices :
    398,440 / 97,209
    Total Triangles :
    2 / 44
    Total Quads :
    395,676 / 95,568
    Total Faces :
    395,678 / 95,612
    Total Lines :
    0 / 0
    Name :
    Cloak_13547
    Label :
    Cloak
    Class :
    DzFigure
    Vertices :
    53,496 / 13,547
    Triangles :
    0 / 0
    Quads :
    52,800 / 13,200
    Total Faces :
    52,800 / 13,200
    Total Lines :
    0 / 0
    Name :
    Bracer_3152
    Label :
    Bracer
    Class :
    DzFigure
    Vertices :
    12,462 / 3,152
    Triangles :
    0 / 0
    Quads :
    12,320 / 3,080
    Total Faces :
    12,320 / 3,080
    Total Lines :
    0 / 0
    Name :
    Girding_9873
    Label :
    Girding
    Class :
    DzFigure
    Vertices :
    39,334 / 9,873
    Triangles :
    0 / 0
    Quads :
    39,176 / 9,794
    Total Faces :
    39,176 / 9,794
    Total Lines :
    0 / 0
    Name :
    Kilt_6318
    Label :
    Kilt
    Class :
    DzFigure
    Vertices :
    100,536 / 6,318
    Triangles :
    0 / 0
    Quads :
    100,352 / 6,272
    Total Faces :
    100,352 / 6,272
    Total Lines :
    0 / 0
    Name :
    Necklace_16294
    Label :
    Necklace
    Class :
    DzFigure
    Vertices :
    64,865 / 16,294
    Triangles :
    0 / 0
    Quads :
    64,560 / 16,140
    Total Faces :
    64,560 / 16,140
    Total Lines :
    0 / 0
    Name :
    Sash_1120
    Label :
    Sash
    Class :
    DzFigure
    Vertices :
    4,320 / 1,120
    Triangles :
    0 / 0
    Quads :
    4,160 / 1,040
    Total Faces :
    4,160 / 1,040
    Total Lines :
    0 / 0
    Name :
    Sandals_12316
    Label :
    Sandals
    Class :
    DzFigure
    Vertices :
    49,312 / 12,316
    Triangles :
    0 / 0
    Quads :
    49,328 / 12,332
    Total Faces :
    49,328 / 12,332
    Total Lines :
    0 / 0
    Name :
    Undergarment_6541
    Label :
    Undergarment
    Class :
    DzFigure
    Vertices :
    25,795 / 6,541
    Triangles :
    0 / 0
    Quads :
    25,424 / 6,356
    Total Faces :
    25,424 / 6,356
    Total Lines :
    0 / 0
    Name :
    Headdress_21226
    Label :
    Headdress
    Class :
    DzFigure
    Vertices :
    21,226 / 21,226
    Triangles :
    2 / 2
    Quads :
    20,662 / 20,662
    Total Faces :
    20,664 / 20,664
    Total Lines :
    0 / 0
  • Hi
    Does my lazy FBX export screen shot give you everything you need?  I have the Barb Queen and Anubis Priest in the scene (everything not B.Q is the Priest stuff)
    978 x 538 - 69K
  • EllessarrEllessarr Posts: 1,395
    wow thanks both, they look around 100k, the BQ is 119174 total while the anubis 90387, well they look's fine for now, the only missing now are the world war and the the jw cloths.
    Ah, hell with it. I was thinking about picking up these outfits anyway.
    JW Outfit A (Top 3, Skirt 1)
    Total Vertices :
    48,882 / 12,360
    Total Triangles :
    0 / 0
    Total Quads :
    48,320 / 12,080
    Total Faces :
    48,320 / 12,080
    Total Lines :
    0 / 0
    Outfit B (Top 1, Skirt 2)
    Total Vertices :
    87,448 / 22,044
    Total Triangles :
    0 / 0
    Total Quads :
    86,720 / 21,680
    Total Faces :
    86,720 / 21,680
    Total Lines :
    0 / 0
    Outfit C (Top 2, Skirt 3)
    Total Vertices :
    68,724 / 17,306
    Total Triangles :
    0 / 0
    Total Quads :
    68,224 / 17,056
    Total Faces :
    68,224 / 17,056
    Total Lines :
    0 / 0
    Pilots Outfit
    Total Vertices :
    100,045 / 100,045
    Total Triangles :
    4,733 / 4,733
    Total Quads :
    95,512 / 95,512
    Total Faces :
    100,245 / 100,245
    Total Lines :
    0 / 0
    Name :
    ParachuteHarness
    Label :
    ParachuteHarness
    Class :
    DzNode
    Vertices :
    344 / 344
    Triangles :
    80 / 80
    Quads :
    292 / 292
    Total Faces :
    372 / 372
    Total Lines :
    0 / 0
    Name :
    PilotsHelmet
    Label :
    PilotsHelmet
    Class :
    DzNode
    Vertices :
    11,289 / 11,289
    Triangles :
    80 / 80
    Quads :
    10,949 / 10,949
    Total Faces :
    11,029 / 11,029
    Total Lines :
    0 / 0
    Name :
    PilotsBoots
    Label :
    PilotsBoots
    Class :
    DzFigure
    Vertices :
    7,318 / 7,318
    Triangles :
    58 / 58
    Quads :
    6,688 / 6,688
    Total Faces :
    6,746 / 6,746
    Total Lines :
    0 / 0
    Name :
    LifeJacket
    Label :
    LifeJacket
    Class :
    DzFigure
    Vertices :
    3,234 / 3,234
    Triangles :
    28 / 28
    Quads :
    3,184 / 3,184
    Total Faces :
    3,212 / 3,212
    Total Lines :
    0 / 0
    Name :
    PilotsHarness_578
    Label :
    PilotsHarness
    Class :
    DzFigure
    Vertices :
    578 / 578
    Triangles :
    22 / 22
    Quads :
    575 / 575
    Total Faces :
    597 / 597
    Total Lines :
    0 / 0
    Name :
    PilotsSuit_25480
    Label :
    PilotsSuit
    Class :
    DzFigure
    Vertices :
    25,480 / 25,480
    Triangles :
    3,083 / 3,083
    Quads :
    23,285 / 23,285
    Total Faces :
    26,368 / 26,368
    Total Lines :
    0 / 0
