Pose Preset Animation for UE Live Link Face Capture
UpL8RenderingUpL8Rendering Posts: 129
edited November 2020 in Unreal Discussion
I made a Daz Pose Preset Animation for all the poses needed for the Unreal Engine Live Link Face capture.
They are all made from the basic Daz head poses. Some may still need work but it should get you started.
It is up on my Github page now. Documentation is in the ReadMe.md file but I will add it below too.
https://github.com/GNVR-Dev/DazPosePreset-ArKitFacePoses
Instead of using morphs this method exports the poses as an animation.  The animation can be shared between characters while maintaining their unique character shape.
This also allows for animation of facial hair, jewelry, or any other item that needs to be attached to a bone that will be following the animation.
Post edited by UpL8Rendering on
  • UpL8RenderingUpL8Rendering Posts: 129
    Basic poses for ArKit Face capture.  Made with default Parameter settings. Saved as Daz Pose Preset.
    Reference Pose:
    Eyes:
    Jaw:
    Mouth
    Cheek, Nose, Tongue
    Unreal Engine Project Setup:
    In your Project Settings make sure the following Plugins are enabled:
    DazToUnreal
    Apple ARKit and Apple ARKit Face Support
    As well as Live Link
    Click Restart Now to restart your project.
    In Daz Studio load a base character into the scene.
    Send the character mesh to Unreal by going to:
    File -> Send To -> Daz To Unreal
    Set the Asset Type to Skeletal Mesh
    Uncheck Enable Morphs
    Uncheck Enable Subdivisions
    and click Accept
    Using Pose Preset Animation
    Download and extract or clone the Github three files into either:
    Daz3DFiles\Presets\Poses
    or
    My Library\Presets\Poses
    Open the ARKitFacePoseNames.txt file
    You will need these names later
    In the Content Library tab, navigate to and double click the ARKitFacePoses preset
    This will pop up a message asking if you want add frames to the timeline. Click Yes.
    All the poses will be added to the timeline.
    Again, go to File -> Send To -> DazToUnreal
    Change the asset name to something like ARKitFacePoses
    This time set the Asset Type to Animation
    Click Accept
    Once imported right click on the animation
    Go up to Create and click Create PoseAsset
    Go back to the ARKitFacePoseNames.txt file and copy all the names of poses
    Paste them into the Pose Asset dialog box and click Accept
    Open the Pose Asset
    In the Asset Details Tab under Additive
    Check Additive and set the Base Pose to the ARKit_Ref_Pose
    Click Convert to Additive Pose
    If you have other characters you can change the Preview Mesh for the animation to see what the poses look like on other characters
    Setting Up the Animation Blueprint
    Right click in the Content Browser
    Mouse over Animation and Select Animation Blueprint
    In the Animation Blueprint AnimGraph right click and create a Live Link Pose node:
    Set the Live Link Subject Name to the device you are using for face capture
    Pull out from the output pin and create a modify Curve Node
    Change the Apply Mode to Weighted Moving Average
    Pull off from the Alpha input and promote to variable
    Change the name of the Variable to WMA_Alpha
    Compile the Blueprint
    and set WMA_Alpha's the default Value to .8
    Pull off from the Modify Curve node and create a node to Evaluate your face poses Pose Asset
    Connect this node to the Output Pose and Compile to test that this part is working OK
    To add head movement pull a pin out and create a Local To Component Node
    Then create three Transform (Modify) Bone nodes and reconnect to the Output Pose (a Component To Local node will be created automatically)
    On each of the Transform (Modify) Bone nodes set the Rotation Mode to "Add to Existing" and the Rotation Space the "Bone Space"
    On the first Transform (Modify) Bone node set the Bone to Modify as neckLower
    On the second Transform (Modify) Bone node set the Bone to Modify as neckUpper
    On the third Transform (Modify) Bone node set the Bone to Modify as head
    Pull off one of the Rotation pins and Make Rotator
    Connect the rest of the rotator pins to the make roator node
    Right click on the graph and create a Get Curve Value node
    Enter headPitch into the Curve name
    add a multiply node and enter -90.0
    add a divide node and enter 3.0
    Duplicate these nodes twice and connect to the Y(Pitch) and Z(Yaw) of the Make Rotator Node
    On the second Get Curve Value node change the Curve Name to headYaw
    On the third Get Curve Value node change the Curve Name to headRoll
    Compile and test.
    If the head movement isn't working it's probably because the skeleton doesn't have a headPitch, headYaw, or headRoll anim curve set up yet.
    In the Skeleton setup of your character go to the Anim Curve tab and search for Head.
    If those curves aren't listed Right Click and "Add Curve"
    Add a curve for:
    HeadPitch
    HeadRoll
    HeadYaw
    Head movement should now be working
    edited September 2020
    Placeholder - Just in Case
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,666
    pity all these facial capture softwares need Apple iphones crying
    I just absolutely refuse to buy one or any expensive smartphone for that matter
    honestly if Apple released a webcam with the same technology I would buy that, just don't like linking my phone to that sort of data, I even unplug my webcam when not in use
  • pity all these facial capture softwares need Apple iphones crying
    I wouldn't be surprised if there was something out there already that you could make work. Apple just makes it easy to use and the FaceARSample Project is already set up to go.
  • I made a Daz Pose Preset Animation for all the poses needed for the Unreal Engine ARKit face capture project.
    Wow, fantastic. :) Ty so much.
  • Wow, fantastic. :) Ty so much.
    You're welcome. I hope it works OK. I'm planning on doing the UE side of the tutorial this weekend.
  • dc8989dc8989 Posts: 0
    Was wondering if you were planning on doing the UE part of this - I got it working on my own with a weird exception: can't seem the get the brows to stop mirroring one another....
  • Very Interesting, I was working on a similar approach for Unity.
    It is important to match ARkit's control points to DAZ for facial animation either for motion capture or for real-time remapping.
    thanks, I will check your approach.
    Sorry, I didn't realize this thread had gotten a couple more responses.
    I was trying to get this working using the UE FaceARSample project as a starting point but I eventually gave up and then got distracted by another couple projects.
    I just updated the tutorial above so you don't have to use the UE FaceARSample project at all, you can just add this setup to your existing project or template.
    I haven't update the Github Read Me file with these changes yet.
  • Awesome stuff, thank you for all the documentation :) Is it possible to use this with the Daz to Unreal exporter or do you have to export via fbx?
    You're welcome.  Yes, the Daz to Unreal exporter will work great for this.  The steps for using the exporter are included in the documentation.
  • Meeeehhhhhhh...
    I'm stuck on the "add a node to evaluate your pose" step.  That option isn't there.  Neither is the Genesis 8 pose that's in your example image :(  I went back, redid everything... and they still aren't showing up :-/  Help?
  • Hello,
    It may be one of two issues.
    When sending to Unreal are you making sure you are changing the Asset Type to Animation?
    If yes, did you do the step where you right click on the Animation and Create a Pose Asset?
  • Hi! thank you for your work
    I have a problem. Avatar is everytime with open mouth and half-closet eyes. When i smile she looks like crying girl. What i made wrong? HELP PLEASE
    1920 x 1200 - 780K
  • https://imgur.com/asiIbV6 ; her face like here
  • Great work! Does this work for G8.1 BTW?
