Pharaoh Makeup not loading
N-RArtsN-RArts Posts: 1,609
edited September 2020 in The Commons
The Geoshells load, but they're not appearing in the surfaces tab. I did get one of the eyeshadows to work, but I keep getting errors with the rest of the makeup set (and I had no idea how I got that one eyeshadow to work in the first place). Could someone please let me know what I'm doing wrong?
Post edited by N-RArts on
  • LindseyLindsey Posts: 2,017
    I loaded and selected a geoshell in the scene tab and applied the appropriate material preset.
    Edit: As I was populating my Daz Studio Format library with links from the Smart Content tab, I noticed the makeup presets are hierarchial, which typically means you select, in this case, Genesis 8 Female, then load the presets.  Let me test the application of the makeup again.  My Genesis 8 Female takes go long to load, decided to edit my comment.
    I attached a sample picture when I tried the product the other day...
    Edit: Tested: Load the "All Shells" to Genesis 8 Female.  With Genesis 8 Female selected, apply any of the makeup presets and they will apply to it's corresponding geoshell. If you have eye shadow applied, it may cover some of the eyeliner makeup.
    504 x 672 - 273K
    Post edited by Lindsey on
  • N-RArtsN-RArts Posts: 1,609
    Beautiful render :3
    I've seen the term "hierarchial" around, but I didn't know what it meant (in the Daz Studio context).
    Thank you for explaining, and replying. ^^
