Issues with Majestic Anubis
Just wondering if anyone else is having issues with the Majestic Anubis character. So far it's caused several render fails and also crashed Daz Studio. I guess I'm just trying to figure out if the issues with my system or the character.
  • A log file would help folk help you ;-)
    Would this be the same thing as the error report? I have that saved as a zip file. The Anubis is the only figure that is causing an issue.
  • I have completed a few renders with the Anubis figure, but it is very resource intensive.  Anubis, the chariot and two horses meant that my system went up to 32GB RAM usage during rendering and DS seemed to freeze at one point.
    The log file is found in Help > Troubleshooting > View log file
  • supernoobsupernoob Posts: 154
    edited September 2020
    Yes, same for me. It just hangs and won't start even a spot render.
    Also, the tail seems to have no textures, in iray view it's always white. Couldn't tell you what it look like in a render because see above.
    Post edited by supernoob on
  • I'm having the same problem. But it crashed my computer instead
    That sounds like a hardware or driver issue.
  • edited October 2020
    maybe. i'm using a gtx1060 with 16 GB ram. this is what the log file caught before the crash.
    2020-10-14 18:05:06.567 Loaded image AnubisTail.png
    2020-10-14 18:05:06.608 Loaded image AnubisTail.png
    2020-10-14 18:05:11.512 Loaded image AnubisTail.png
    2020-10-14 18:05:11.555 Loaded image AnubisTail.png
    2020-10-14 18:05:14.415 Loaded image Face.png
    2020-10-14 18:05:14.494 Loaded image Torso.png
    2020-10-14 18:05:14.529 Loaded image Face.png
    2020-10-14 18:05:14.596 Loaded image Legs.png
    2020-10-14 18:05:14.662 Loaded image Arms.png
    2020-10-14 18:05:14.760 Loaded image Face.png
    2020-10-14 18:05:14.823 Loaded image Torso.png
    2020-10-14 18:05:14.856 Loaded image Face.png
    2020-10-14 18:05:14.917 Loaded image Legs.png
    2020-10-14 18:05:14.983 Loaded image Arms.png
    2020-10-14 18:15:19.559 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to read https://hpclscruffy.daz3d.com/Server/ping?SID=gqdaui0qbik67q4v7qnao5vv70 trying again, curl error was: Timeout was reached
    2020-10-14 18:23:33.153 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to read https://hpclscruffy.daz3d.com/Server/ping?SID=gqdaui0qbik67q4v7qnao5vv70 trying again, curl error was: Timeout was reached
    2020-10-14 18:26:37.868 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to read https://hpclscruffy.daz3d.com/Server/ping?SID=gqdaui0qbik67q4v7qnao5vv70 trying again, curl error was: Timeout was reached
    2020-10-14 18:26:46.446 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): curl_easy_perform(https://hpclscruffy.daz3d.com/Server/ping?SID=gqdaui0qbik67q4v7qnao5vv70) failed: Timeout was reached
    2020-10-14 18:31:32.356 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10053
    at this point it just freezes then crash. just for using the fur
    Post edited by wickedbishonen_e4317deb31 on
  • Despite the "currl" those are not related to fur, they are related to the Daz Connect accessing the Daz servers. Try Connect>Work Offline, but I suspect the log is a red herring and that whatever happened came later (unless network issues are an early sign of the ahrdware issue that caused the crash).
    Hi there!
    There is any solution this above problem? Because It don't working the Bear Clan model too for me. I has the exact same problem with that model. Strange... other RawArt models is working fine. These two has a problem. I'm sad. I tried everything what I knew.
  • NorthOf45NorthOf45 Posts: 5,888
    They each need at least 24 GB of free RAM, probably more, and the figure alone won't even try on a GTX 1080 8GB card, even after closing all memory hogs and restarting Studio to get RAM and VRAM use to a minimum. The fur is what is using all the resources. Line tesselation is at 3 for renders by default, you could try 2, the figure is still suitably furry, and will use my GPU. Once. Second render drops to CPU.
