camera
laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
Hi!!! I have a problem with camera... I have the default "camera1", and I create a second camera , "conical"... this camera once selected, the render is always with "camera1", not the new one... in the assembly room, the view is really by the "conical" camera, but it doesn't change, in the render room... thank you for advice!!!
  • SileneUKSileneUK Posts: 1,980
    edited July 2014
    When you say "select"....where are you choosing it from? If you say your scene is being viewed with the new camera it sounds right, but sort of not if it's not rendering from it.
    Just to check. If you select it in the tree list of items on the right of all the content in your scene, the camera will be selected in the scene, but you have to select it from the upper left corner of your scene where there is a menu for the actual camera position to change.
    Put your cursor there and click, it will show what is available. You should see your new camera there along with Camera 1 and Director's Camera (which does not show in the tree list on the right.) The camera angle chosen from upper left menu should be the same as the render?
    Sorry for weird explanation.... does that help?
    :blank: Silene
    Adding image:
    284 x 423 - 48K
    Post edited by SileneUK on
  • Max TurladMax Turlad Posts: 84
    edited July 2014
    Hi,
    in "render" -> "output" tab you can't select the camera?
    348 x 397 - 108K
    Post edited by Max Turlad on
    sbilf said:
    Hi,
    Oh I forgot about that... I set mine up as I test render every few mins and don't change the camera for that as I keep the same position whilst composing! That's surely his problem.
    Thanks :) Silene
    Silene ;-)
    Ciao, Max.
    Thanks, Son. ;)
    Thanks, Son. ;)
    I'm sure he'll appreciate the sentiment, Gramps! How old is your little grand-rugrat now?
    Hahahahaha thank you, dad.
  • laverdet_943f1f7da1laverdet_943f1f7da1 Posts: 252
    thank you sbilf!!! that solve the mystery!!!
