When rendering, it automatically turns to CPU. How to solve this problem
Version 4.12, graphics card model is 2080ti,The graphics driver is up to date,Not checkedCPU,Only one character is rendered, no scene
The rendering log is as follows:
Rendering in NVIDIA Iray
Compiling Shaders - 0/1
Rendering image
Rendering...
Iray (Statistics) : Geometry memory consumption: 145.450 MiB (device 0), 0.000 B (host)
Iray (Statistics) : Native CPU code generated in 0.094s
Iray (Iteration) : 1
Iray (Canvas) : Render target canvas was written.
Iray (Iteration) : 2
Iray (Iteration) : 4
Iray (Iteration) : 8
Iray (Iteration) : 16
Iray (Iteration) : 32
Iray (Iteration) : 62
Iray (Iteration) : 92
Iray (Iteration) : 122
Iray (Iteration) : 152
Iray (Iteration) : 182
Iray (Iteration) : 212
Iray (Iteration) : 242
Iray (Iteration) : 272
Iray (Iteration) : 304
Iray (Iteration) : 339
Iray (Iteration) : 376
Iray (Iteration) : 415
Iray (Iteration) : 459
Iray (Iteration) : 509
Iray (Iteration) : 557
  • After exiting the software, the log after rendering is reloaded, and it is converted automatically during the rendering process CPU,
    Rendering image
    Rendering...
    Iray [VERBOSE] - IRAY:RENDER :: 1.5 IRAY rend progr: CUDA device 0 (GeForce RTX 2080 Ti): Processing scene...
    Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend stat : Geometry memory consumption: 74.3542 MiB (device 0), 0 B (host)
    Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend stat : Texture memory consumption: 750.811 MiB for 60 bitmaps (device 0)
    Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend stat : Lights memory consumption: 196 B (device 0)
    Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend stat : Material measurement memory consumption: 0 B (GPU)
    Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend stat : PTX code (155 KiB) for SM 7.5 generated in 0.133s
    Iray [VERBOSE] - IRAY:RENDER :: 1.6 IRAY rend stat : Materials memory consumption: 198.441 KiB (GPU)
    Iray Iteration: 1
    Iray :Render target canvas was written.
    Iray Iteration: 2
    Iray Iteration: 4
    Iray Iteration: 8
    Iray Iteration: 16
    Iray [VERBOSE] - IRAY:RENDER :: 1.5 IRAY rend progr: CPU: Processing scene...
    Iray [VERBOSE] - IRAY:RENDER :: 1.9 IRAY rend stat : Native CPU code generated in 0.125s
    Iray Iteration: 17
    Iray Iteration: 18
    Iray Iteration: 20
    Iray Iteration: 24
    Iray Iteration: 32
    Iray Iteration: 48
    Iray Iteration: 77
    Iray Iteration: 106
    Iray Iteration: 134
    Iray Iteration: 163
  • SevrinSevrin Posts: 6,313
    Is there anything else using the GPU while this is going on?
    Nothing else
  • Update driver
  • You say the graphics driver is up to date, but exactly which version is it? And which version of DS (Help>About Daz Studio)?
  • Has ther been any resolution to this issue.
    I have an RTC 2060 and the Cuda core are no longer be utilized. The CPU maxes oput along with RAM and C drive is having numerous reads and writes. Normal rendering has everything contained in CAM with no C drive usage and the Cuda Cores get maxed out.
  • 793043235793043235 Posts: 22
    edited September 2020
     It's the video card failure. However, 2080ti ,But for a 750 graphics card, loading G3 or CPU rendering
    Post edited by 793043235 on
    The driver is 446.14 and the version is 4.12.1,  It's the video card failure. However, 2080ti ,But for a 750 graphics card, loading G3 or CPU rendering
  • 793043235 said:
    Loaded a G3 man's shirt with 750,Here is the log
    Rendering image
    Rendering...
    Iray (Statistics) : Geometry memory consumption: 10.695 MiB (device 0), 0.000 B (host)
    Iray (Statistics) : Texture memory consumption: 110.269 MiB for 3 bitmaps (device 0)
    Iray (Statistics) : Lights memory consumption: 196.000 B (device 0)
    Iray (Statistics) : Material measurement memory consumption: 0.000 B (GPU)
    Iray (Statistics) : Materials memory consumption: 43.051 KiB (GPU)
    Iray (Statistics) : Native CPU code generated in 0.000s
    Iray (Iteration) : 64
  • Get DDU, Disply Driver Uninstall, get the latest driver directly from Nvidia. Do a clean uninstall of the current driver then install the latest driver. If that doesn't correct the issue get back to us.
    Thank you. I'll try again after the 2080 video card is fixed in a few days
    If your monitor was plugged into the card and it was displaying output why did you think it needed repair and what repair did you think could be done without RMA?
  • 793043235 said:
    获取DDU,卸载驱动程序,直接从Nvidia获得最新的驱动程序。彻底卸载当前驱动程序,然后安装最新的驱动程序。如果那不能解决问题,请联系我们。
    谢谢。几天后修复2080视频卡后,我会再试一次
    如果您的显示器已插入卡中并且正在显示输出,为什么您认为它需要维修?您认为没有RMA可以进行哪些维修?
    显卡坏了,没有更换,玩大型游戏会跳出来,出现花屏现象,客服测试坏了
  • My mandarin is crap, sorry.
    The video card is broken, it hasn't been replaced. If you play a large game, it will jump out and the screen will appear. The customer service test is broken,A new one is all right. Thank you very much for your help
