Clicking the eye no longer hides bones
I'm not sure if I changed a setting somewhere or something but clicking the eye on a bone is no longer hiding that part. If I click on the eye for the top-most part, everything hides but not things such as the arm for a character.
  • kaotkblisskaotkbliss Posts: 2,918
    Some more info:
    This is happening on my install of 4.12.1.118 and 4.10.0.123
    It also seems to "click through" parts. Such as if I click on G8's forearm, it selects the thigh instead and won't ever select the forearm unless I select it through the node tree.
  • Sounds as if there may be an issue with grouping. If you switch to the Geometry Editor tool and open the Tool Settings pane do the eyes there hide the expected parts of the model?
    Wow, that does indeed look to be the problem. I opened Geo-editor and in the grouping category, most every limb for G8M has 0 faces assigned to them.
    No clue how that happened :(
  • A reinstall should fix it.
