G8F Base Distortion
front and rear views of my G8F Base figure. there is a distortion there and I don't know how to fix it.
https://mega.nz/file/qw0xgaob#PYraO-k7VJVG7qZKnqYJuiqzaDOC1xaPXRT56kF_CnA
https://mega.nz/file/DokTXarJ#wPwnw9DHAagWWpr1i8wD5sWB-nisinUPefZMlK9lUv8
Below is a file inspection of the saved figure if this helps any.
I don't have a clue what the item I highlighted is.
Scene File: E:\Daz Models\Characters\G8F Base.duf
Date: 9/10/2020 8:03:24 PM
Library Resources [25] =========================================================
    /data/DAZ 3D/Genesis 8/Female Eyelashes/Genesis8FemaleEyelashes.dsf
    /data/DAZ 3D/Genesis 8/Female Eyelashes/UV Sets/DAZ 3D/Base/Basic Female.dsf
    /data/DAZ 3D/Genesis 8/Female/Genesis8Female.dsf
    /data/DAZ 3D/Genesis 8/Female/UV Sets/DAZ 3D/Base/Base Female.dsf
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasearmsmapb_1004.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasearmsmapd_1004.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasearmsmaps_1004.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasearmsmapsss_1004.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaseeyelashes_1006.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaseeyes01_1007.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaseeyesb_1007.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasefacemapb_1001.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasefacemapd_1001.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasefacemaps_1001.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasefacemapsss_1001.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaselegsmapb_1003.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaselegsmapd_1003.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaselegsmaps_1003.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbaselegsmapsss_1003.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasemouthmapb_1005.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasemouthmapd_1005.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasetorsomapb_1002.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasetorsomapd_1002.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasetorsomaps_1002.jpg
    /runtime/textures/daz/characters/genesis8/femalebase/g8fbasetorsomapsss_1002.jpg
External Resources [1] =========================================================
    /resources/DTHDR-RuinsB-500.hdr
  • barbultbarbult Posts: 27,065
    The highlighted item is the default HDRI in the Render Setting pane Environment.
  • kool, got it thank you.
    Still have distortions though.
  • skinklizzardskinklizzard Posts: 218
    edited September 2020
    you probably have a morph that is applying when it shouldn't, go to parameters > currently used, you may need to show hidden paramters too.
    go through the list of currently used parameters and adjust them to see which might be causing it.
    I set up g8f in a similar leg pose and have attached a screen grab of the leg correctives in use
    505 x 598 - 153K
    Post edited by skinklizzard on
  • benjamincobb777benjamincobb777 Posts: 65
    Awesomeness! My mistake was I didn't select "currently used" so searching for the problem was very difficult. There were 5 Items messy me up. Thank you so much for the screenshot!
    *UPDATE*
    Fixed a lot of distortion issues but still have gen area distortions. Still trying to figure out what is distorting it.
    Post edited by benjamincobb777 on
  • https://www.daz3d.com/forums/discussion/248996/genesis-8-female-what-s-going-on/p2
    thread with similar issue, do you have the big girl morphs installed?
    https://www.daz3d.com/big-girl-morphs-for-genesis-8-female
    if so apparently removing them or making sure you have the genesis 8 female body morphs (required products) installed will help
  • yes, I do have the big girls morphs. Let me read your posted link real quick.
