dForce "shrink-fit" help needed
I admit that I'm having a bit of a brain-fart here... I have a swimsuit/leotard that I had made for G3F that I want to fit to G8F.  What I want to do is to use dForce to help fit this to G8F, and then export to Hexagon for more fit adjustments, etc.  From back in the POSER days, you could set V3, V4, or Genesis to 95% scale at frame 1 and 100% scale at frame 5.  When the clothroom was run, the figure expanded, pushing the cloth out to fit the shape of the figure you were trying to match.  I had seen how to do this with dForce, but I forgot the steps and where i had found the instructions to do so.  Does anyone have a suggestion or link to a tutorial on how to do this in DAZ|Studio?
Thanks,
-David
  • GordigGordig Posts: 10,847
    dForce also has a parameter called something like "expansion-contraction ratio" that might be useful for this.
  • barbultbarbult Posts: 27,655
    G3F and G8F have the same body shape. If the swimsuit fits G3F, it should fit G8F the same way. dForce should not be needed. Autofit should work fine.
  • RGcincyRGcincy Posts: 2,864
    @Starkdog This tutorial covers both scaling up and down clothing.
  • RGcincy, YES!!!  That is what I was looking for!  I had forgotton that the specific process/tutorial was covered in your thread.  I'm trying it out and will see how things work out. -David
