Puzzling MTMirror errors.
ghastlycomic
Anybody here have experience with MT Mirror?
I've been getting puzzling error messages when I try to open the base for a new figure I built. The figure should be perfectly symmetrical but when I load it into MTMirror the error message I get is "NG Mirror V.C.M. can't build up".
I have no idea what that means or what I need to do to fix it.
Hmmmmm.... I've been experimenting by sending the individual component of my new figure to MTMirror one at a time to see what is causing the problem. It would appear that the culprit is the teeth. From everything I can tell my teeth should be perfectly symmetrical. The only thing different between the teeth and the rest of the mesh is the teeth have a number of intersecting geometries so that they won't have huge gaps between them when subdivided.
Could it be that MTMirror has problems with intersecting geometries? If so why doesn't it balk at the Genesis mesh which has lots of intersection in the teeth as well?
