V4 error loading G2F Jasmina. "The Girl" with V4 Jasmina???
ZarconDeeGrissomZarconDeeGrissom Posts: 5,414
edited July 2014 in New Users
(edit; I am aware that this is a new product with some "Teething Pains", Pleas don't think this is a bad product simply because I have no clue what I'm doing)
I took the time between storms to test some stuff purchased yesterday, and when I got to Jasmina
http://www.daz3d.com/jasmina-for-victoria-4-and-genesis-2-female-s
Loading the "!Jasmina Mat.duf" onto G2F base, I got this file not found Error.
The funny thing is I have V4.2, and V4 shapes thing for G1. I shouldn't be getting this error, or am I missing a requirement?
(edit)
Clicking past that, It gets better.
That splotch up the side of her head, there splotches like that all over the body.
1750 x 871 - 257K
456 x 310 - 6K
  • Scott LivingstonScott Livingston Posts: 4,352
    One of the requirements is Victoria 4 for Genesis 2 Female. Do you have that one installed?
  • JaderailJaderail Posts: 0
    edited July 2014
    The proper UV for that Texture was not loaded to the figure, that is why the Mat looks so wrong. It probably needs the V4 UV applied. No clue why you got that error I do not think it should do that.
    EDIT: Scott is spot on, it Auto loads properly only with that Set installed.
    Post edited by Jaderail on
    Opps, I missed a V4 pack??? I didn't notice that requirement, the store was messing up again.
    I need "V4 Morphs++", how many times? lol.
    I have "Victoria 4 3D Model Pro Suite", and it dose not include that V4-for-G2F thing, hmmm
    http://www.daz3d.com/victoria-4-3d-model-pro-suite
    Whats the third "V4 Morphs++" supposed to be?
    986 x 987 - 547K
    edited July 2014
    You need EACH required item ONE time each and EACH required item MUST all be in the Content folder READ at the use of the item that calls all the requirements. This can be two content folders AS LONG as both folders are Properly MAPPED as Paths in DAZ Studio. Nothing more nothing less, for BEST use one single content folder solves many errors.
    Having TWO of a item like V4 Morphs++ installed, one in a DAZ Studio content folder and a Second in a Poser only Content folder and having Those both mapped can and WILL break them from working properly.
    EDIT: And yes the Requirements for items get flagged wrong often.
    If you want to use her on the original V4, then you need V4 and V4 Morphs++
    If you want to use her on G2F, then you need G2F, the V4 for G2F product that Scott linked, and http://www.daz3d.com/new-releases/genesis-2-female-body-morphs
    Jasmina works with two completely different figures. You don't need V4's Morphs++ if you plan on using her with G2F.
    edited July 2014
    That is Correct as well, you only need the required items for the Generation Figure you will use. For use on both V4 AND G2F you need all items, for G2F you only need the G2F items that are required.
    So in the mean time, with “Victoria 4 3D Model Pro Suite”, I should be able to bring up the figure... assuming I can find the V4 duf things, there not in the Daz side of the Content Library.
    Jasmina For Victoria 4 Ps
    You can find new icons for loading this product in the following Poser Libraries:
    Pose: “A_Jasmina:00 Morphs”
    Pose: “A_Jasmina:01 Poser 6+ MATS”
    Pose: “A_Jasmina:02 Poser 9+ MATS”
    I didn't look there, yet...
    V4 is not DUF it is now and always has been Poser CR2 content, the New content you bought is designed in both formats just for that reason.
    edited July 2014
    Depends if you want to use her with V4. Your original post had you using G2F. Victoria 4 3D Model Pro Suite has nothing to do with G2F.
    Post edited by Lissa_xyz on
    That was my first attempt, as I like the movement of G2 better then genesis1. The name of the game is to see the figure load, so I know the purchase was not a bad one...
    And the rumbling and light-flickering is back (lightning), chat later...
    Victoria 4 is not Genesis 1 it is Generation 4, Genesis is Generation 5 thus the V5 for genesis 1 and the Genesis 2 Female is generation 6 thus the V6 for G2F. All generations are different and each is one step above the other in order of when they were built. The Generation 4 figures being the oldest and longest supported of the 3 and the Genesis 2 figures the newest. All figures including the Generation 4 figures were built as Poser figures before Genesis. Genesis 1 was the very first DAZ Studio based Figure and all Genesis figures of both generations of genesis are DAZ Studio based figures. All others were built to work in Poser just as well as DAZ Studio because DAZ Studio started life as a POSER content render program. And then became a Poser type content Site that created the Victoria/Micheal line of Poser figures. Which became the most widely used 3D figures on the market.
    Victoria 4 is generation 4 and is 100% Poser type content, nothing DAZ Studio is needed to use in Poser.
    Victoria 5 is generation 5 and is Genesis 1 only, needing the DSON importer or another importer to work in Poser.
    Victoria 6 is generation 6 and is Genesis 2 Female, also needing DSON or another importer to work in Poser.
    edited July 2014
    yea, I kinda left out the "And earlier" bit there, lol. I was typing in a hurry as I was grabbing my radio to head out the door.
    Lets try the other as G2F will need to wait. While I'm trying to locate that "Pose" folder.
    I take it "UV", is not Ultra Violet, as in the EVE (Extreme ultraviolet Variability Experiment)?
    What is this "HD" vs regular figures thing?
    Phobe vs "Phobe HD"
    Is "name.PZ2" the same as a CR2?
    1582 x 766 - 122K
    edited July 2014
    Check that... Aparently "The Girl" (whatever the hell that is, and I DON'T Want to know, lol), is requierd for the V4.2 version of Jasmina.
    984 x 774 - 74K
    That might be a mistake, just hit skip.
    Girl 4 is just a stylized morph for V4 in the same fashion there's a Girl 6 for G2F.
    http://www.daz3d.com/the-girl-4-base
    talk about "Teething Pains", lol.
    That just dose not look anything close to correct with the "sss" shaders. It's like a Glazed Porcelain figurine.
    600 x 800 - 465K
    Poser SSS won't work in Daz Studio. Try using the mats meant for G2F.
    I just tried that, lol. The V4 undergarments and skin-tone is still there.
    It went threw some kind of load window, and nothing else happened. I think the G2F mats need that V4-for-G2F.
    There is a Non-SSS shader in the Poser paths, I'll try that now. Just for morbid curiosity, lol.
    600 x 800 - 476K
    Artemis3d, Whatever you do to work the other problems, DON'T Touch the "01 Poser 6+ MATS" path. It's the only thing that loads without errors or warnings.
    900 x 1200 - 1M
