Age of armour, Advanced lights and Flagging objects question
craftercrafter Posts: 9
Hello Daz people
Just a quick question .... how do you flag an item in Advanced Ambient Light pack by age of armour so the light only effects that item ?
Cheers
  • Scott LivingstonScott Livingston Posts: 4,352
    edited July 2014
    Select the Advanced light, go to the Parameters pane (or Lighting pane), then under Lighting Control, go to If Surface Is Flagged... and choose "Illuminate Flagged Only."
    If you're asking how to actually flag something, there are several methods, but I usually set the Diffuse Strength to 99% of the item I want to flag, then tell the Advanced Light to flag objects with a diffuse strength of 99%: Lighting Control>Flag Surface Shaders With...>Diffuse Strength of...; Diffuse, Ambient, or IOR Value 99%.
    Hopefully those instructions are understandable, but if you need more detail, I highly recommend reading the Advanced Ambient Light user guide: http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/17031/17031_advanced-ambient-light.pdf
    Post edited by Scott Livingston on
  • craftercrafter Posts: 9
    Thank you ... thank you ... thank you
    its the 99 % wasn't clicking in my brain
    thanx for the info Scott :-)
