Render Mesh
Kendall SearsKendall Sears Posts: 2,995
OK folks.... I've run into something in DS that I don't know: I need to render the raw Mesh of an item. Either the Lit Mesh with Occlusion or a transparent mesh will work.
Anyone know how to do this? Commercial options are welcome.
Kendall
  • fixmypcmikefixmypcmike Posts: 19,742
    Set viewport to wiremesh and do an OpenGL render?
  • Kendall SearsKendall Sears Posts: 2,995
    Nice suggestion. :-) Tried it before posting. Still renders the full model surfaces.
    Kendall
    Kendall
    Latest version of DS?
    Kendall
    Actually. No. I was using it on a machine running DS 4.6.2.120. I'll try it on a more recent version.
    Kendall
    Kendall
    Kendall
    It should work on 4.6.3.12 or higher.
    Kendall
    Kendall
    4.6.3.52 will do it if the quality is set to 1. Which is not an acceptable solution for this. I need both textured and "meshed" items in the scene. If I'm forced to composite then I'll jump out of DS and use Maya or something. I was hoping to make this a "quicky" for a proposal. Nothing in Maya/3ds is quick.
    Kendall
  • Richard HaseltineRichard Haseltine Posts: 112,049
    The traditional approach is to use a high-resolution texture template as a transparency map. I did try experimenting in Shader Mixer a while back (DS3 era, I think) with using the normals or the normal derivatives to spot mesh transitions (would probably work best with smoothing off) but of course that would always fail with boundaries between co-planar polygons and I don't recall getting very good results (I think I managed to get very faint mesh lines, but not to get them really strong).
  • MattymanxMattymanx Posts: 7,002
    YOu can use the Advanced Ambient light to render an AO image and very quickly too.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,836
    buy Poser or Carrara?
    Have both. Was looking for a quick DS solution.
    Kendall
    I have the Advanced Ambient, but I haven't found a way to make it show the mesh. AO is easily done in many ways.
    Kendall
  • millighostmillighost Posts: 261
    Kendall
    If by "raw mesh" you mean a wireframe, you can try this one:
    https://sites.google.com/site/millighostmix/home/wireframe_script
