can I stop my dforce hair taking forever to render?
So no matter what dforce hair I use on a G3/G8 character it takes FOREVER to render an Iray image like I'm talking close to 3 hours just for a single G3 simple background and character and the hair where with just normal iray hair that isn't dforce it would take about 20 mins for the whole scene. I assume because dforce products including hair are very system taxing to render this happens so what can I change to make this a lot quicker please?
  • TheKDTheKD Posts: 2,711
    Sounds like it might be running out of vram and using to cpu render maybe?
  • JabbaJabba Posts: 1,464
    What I'll often do is render until most of scene looks OK, then run denoiser and sharpen image in Photoshop - my PC is getting old and would spend 5 hours or so rendering out shadows if I never use denoiser.
  • vagansvagans Posts: 422
    This is probably the reason. dforce hair can generate massive amounts of geometry, possibly causing the VRAM to fill and fallback to CPU rendering.
  • DrekkanDrekkan Posts: 460
    hmmm ok any idea's what I can do here?
  • what settings are you using on the hair for line tesselation sides ?
    how much vram does your card have ?
    dedicated video memory: 6144 MB
    sorry would you explain the line tesselation sides question?
  • select the hair, then in parameters pane under general > line tesselation. you will see options for line tesselation sides both viewport and render.
    a value of 3 will make each strand a triangular tube which will nuke your vram with geometry, for render you can try 1 but results vary and the hair might not look good, I usually use 2 for ribbons though.
    if its already at 1 then I'm not sure what you can do, there might be surface settings to reduce geometry but those will have a fairly large effect on the looks
  • GazzalodiGazzalodi Posts: 50
    edited September 2020
    I don't do Iray, but...
    Can't you just get your figure into the pose you want, run the dforce simulation, hide everything but the hair, export it as an obj, import it back as a prop with no rigging or extra dforce info, apply the textures from the original hair, delete the original hair and render?
    Post edited by Gazzalodi on
    No its ok I took Skinklizzards advice and it seems to work a lot better as a result. Thankyou all :)
    no because strandbased hair is curves so creating an obj from it requires line tesselation which gets a massive amount of geometry and then the specialised shader no longer works on it either
