Crash when I want to find a file in Carrara
JamyJamy Posts: 192
Hi, a long time without discussion, but to much work and to hard language for me. (but every day I had a look to the forum)
Today I've a big problem with Carrara:
if i open a Carrara file and if carrara don't find a texture or a mesh, a new window is open to find it, but when I write the first letter of this file, Carrara Crash.
I've uninstall Carrara and try with a new one, but Carrar crash again
Could you help me pleased ?
Regards
A chaque fois que Carrara recherche une texture, il suffit que je tape la première lettre du fichier à rechercher dans la fenêtre pour que le logiciel plante.
  • JamyJamy Posts: 192
    My system is Mac OS 10.9.3
    To make sure I understand, you open a file and Carrara doesn't know where it is, then Carrara opens a window and asks you to locate the file? When you begin to type, Carrara crashes? How does it crash? Does it freeze, or does Carrara quit unexpectedly?
    Hi,
    You know, when you change the place of a texture, when you open Carrara, you must locate it.
    when I try to locate this file, most of the time, I just write the first letter and Carrara Crash. Freeze or quit, it's depend of the time.
    What if you were to press cancel instead? Does Carrara still crash?
    No crash when I press cancel
    Does it happen with any file, or is it with pre-made figures like, V4 or Genesis?
    Sorry for all the questions. Just trying to isolate possible cause of the problem.
    It's with any figure. I've make a test with a simple cube and a very small JPG texture.
    Then, I quit Carrara and I put this texture in a new folder
    When I open the Carrara file, Carrara ask me to locate this JPG and when I writ the first letter Carrar crash
    The same when I want to locate in the texture room
    978 x 553 - 259K
    I've never tried using Spotlight in that situation. I recently had the circumstance after I renamed the folder. I just browed to the new location using the list on the left. Once it found the first one, getting to the same place again for further files is just a matter of going straight to the recent folders drop down ("Bureau" on your screenshot).
    Other times I just pressed Cancel and reassigned the texture from the shader editor.
    I'll try typing in the Spotlight box tonight when I get home.
    (also 10.9.3)
    I don't use Mavericks, so I'm at a bit of a loss. I can use the find feature in Carrara 7.2 Pro with OS X 10.4 .11 and 10.5. Since you're moving these files, I assume that you know where you're moving them to? Maybe just navigate to them?
    I would still file a bug report for this issue if it is reproducible. I'm not sure if it's a Carrara issue or a Finder issue. Obviously the Finder and Carrara are having a conflict with each other on some level.
    (also 10.9.3)
    Sometime I don't know where are the files, so it's very useful to use Spotlight. Never had problem with 10.6.8
    Yes, I think it's a conflict. Spotlight works well alone
    Ok, I've tried it with Spotlight, and no crash. So I guess it's something particular to your setup. Sorry :(
    Tim,
    thank you for this try.
    I really want to find a solution.
    Maybe try again to uninstal Carrara ?
    (also 10.9.3)
    I must admit, I've never tried using that search box either. Like Tim, I either locate the file or I just cancel out and reassign.
  • pimpypimpy Posts: 274
    Hi Jamy,
    it's a stupid tip, but did you try to serch the file from folder and click on it without write the name file?
    (also 10.9.3)
    I've used it before, but haven't had any crashes because of it. That's why I was asking all the questions.
    Hi Jamy,
    As I said, sometime I don't know where is the file. By exemple: I've purchase TP Lightdomes, but When I open a carrara file make with a computer, it's not easy to locate a lightsource on an other one computer (a new Mac) or sometime it's a very old file and I don't remember where are the textures sources.
    So, it's very useful to use Spotlight integrated in Carrara.
    But I could use the Spotlight on the desk (the finder) and then come back in Carrara and choose the good folder, but it's longer
    Same for me, never had this problem before !
    I've just buy a very big powerful super Mac … but… the best is the enemy of the good ;)
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    carrara has coped using the search box for me but is a bit dodgey can freeze
    I prefer to seach in windows explorer first then browse straight there
    other programs I have used nearly always crash or freeze up doing it too so by no means unique to carrara.
