Create Clip
Oldminer
I have keyframed a number movements for my figure and keyframed several camera movements to correspond to the figure movements.
Can I incorporate the camera movements in a NLA Clip of the figure? So far none of the figure clips I have made include Camera moves.
You would have to have the cameras in the same Animated Group, and then create the clip, making sure that when the window for setting the clip parameters opens, there's a check mark for the cameras in the group.
If the figure is a DAZ or Poser figure, you should be able to drag the camera into the hierarchy. Just make sure it is not parented to a bone, but is at the same level as Model or Actor (if Genesis). That should do the trick.
Thanks both work just have to adjust some parameters.
