Can't open any previously created Daz files!
I recently upgraded my mac and had to transfer everything to the new iMac. I now have Daz running just fine, except when I want to go back into a Daz file I worked on previously, I can't open it. That's absolutely screwy. I already had to redo on scene, but obviously I don't want to have to do that every time.
 Looking at the files from the Finder, the appearance looks fine, but nothing happens when double clicking on it. I can open Daz, and work in it on a new document, but am unable to open any Daz files.
HELP please!
1085 x 498 - 219K
  • Which version of DS? Help>About Daz Studio.
  • 4.12.0.86
  • LeanaLeana Posts: 13,659
    At a guess you upgraded to Catalina? If so you'll need to install the latest version of DS. Catalina broke a few things in DS and the version you have doesn't include the fixes for those problems.
  • You may find that you can drag a scene file into the Viewport of an open DS and have it load, but updating is the official fix. Do be aware, if you use animation, that there is a serious issue with saving scenes that can result in the loss of some keyframes - Daz is aware of the issue, and a workaround seems to be to save pose/shaping presets as well as the full scene; if you don't animate this isn't an issue, of coruse.
  • Thanks! I did upgrade to Catalina and thankfully I am not using animation. I will upgrade DS.
  • Oops - how do I upgrade DS? I looked under Preferences and DIM and am not sure where to go to upgrade?
  • Assuming you isntalled through Install manager or Daz Central the new version will be available when you log in. There isn't currently a stand-alone installer for Mac, so if you used that previously you will need to uninstall and install through DIM/Daz Central.
