Error opening basic genesis figures male and female
When I try to use either the male or female basic genesis figure, I get a dialog about duplicate entries and to check the log file. This is what is in the file:
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 9 unknown for QWidget)
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 3 unknown for QWidget)
*** Scene Cleared ***
WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/MCMA4EyesClosedR.dsf#MCMA4EyesClosedR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMEyesClosedR.dsf
WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/MCMM4EyesClosedR.dsf#MCMM4EyesClosedR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMEyesClosedR.dsf
WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/MCMV4EyesClosedR.dsf#MCMV4EyesClosedR?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMEyesClosedR.dsf
WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/MCMA4EyesClosedL.dsf#MCMA4EyesClosedL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMEyesClosedL.dsf
WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/MCMM4EyesClosedL.dsf#MCMM4EyesClosedL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMEyesClosedL.dsf
WARNING: fileinput\dzassetdaz.cpp(5230): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/MCMV4EyesClosedL.dsf#MCMV4EyesClosedL?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/PHMEyesClosedL.dsf
WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking ZRotate & CTRLArmsDownRight in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownRight.dsf.
WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking XRotate & CTRLArmsDownRight in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownRight.dsf.
WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking YRotate & CTRLArmsDownRight in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownRight.dsf.
WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking ZRotate & CTRLArmsDownLeft in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownLeft.dsf.
WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking XRotate & CTRLArmsDownLeft in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownLeft.dsf.
WARNING: fileinput\dzassetdaz.cpp(5463): Duplicate formula found linking YRotate & CTRLArmsDownLeft in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Base/CTRLArmsDownLeft.dsf.
Any ideas on what it all means?
You need to make sure that you have the latest versions of the Genesis Starter Essentials, and Genesis 2 Starter Essentials installed.
Did you install these items using the DAZ Install Manager (DIM)?
You could also have a look at this post here : http://www.daz3d.com/forums/discussion/42410/#622906
Thanks. I did install using DIM (tried uninstalling and reinstalling as well). I'll take a look at the thread and see if anything there helps. I did try to run DS as admin and I did not get the error. So now I'm wondering if it is a permissions/setup issue. But I'll look at the thread first.
