D-Force not working correctly
My 3D Spin
in New Users
Since i inatlled DAZ Studio to my new Hard drive D-Force just gets stucked with "not responding"
during Stabilization. I noticed also that my GPU goes up to a 100%
Is there any fix for this?
What are the system specifications? What is your OpenCL provider, set in the Advanced tab of Simulation Settings?
I now choose NVDIA CUDA GeForce GTX 950M in open CL Device
and get this message: It appears that the DForce kernels on your computer for "GeForce GTX 950M"
have not been compiled or have changed and need to be recompiled. This process can take several
minutes to complete.
Would you like to continue
Is this safe and what does it do to my GEForce?
doesn't effect your card at all, its safe, and required.
it means it needs to compile the dForce code to run with your chosen hardware
Ok, Thanks. that worked perfectly!
I have a similar problem. In the past I was able to simulate and render pretty succesfully. I'm pretty sure things got wonky after a windows or driver update. I have no idea how to fix this. I have tried to install previous versions of Intel UHD Graphics 630 but no success.
Any guidance would be appreciated.
OS Name Microsoft Windows 10 Pro
Version 10.0.18363 Build 18363
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-9O2T8TE
System Manufacturer Micro-Star International Co., Ltd.
System Model MS-7C31
System Type x64-based PC
System SKU Default string
Processor Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz, 2808 Mhz, 6 Core(s), 6 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1.40, 2020/01/07
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Micro-Star International Co., Ltd.
BaseBoard Product B365M PRO-VH (MS-7C31)
BaseBoard Version 1.0
Platform Role Desktop
Installed Physical Memory (RAM) 16,0 GB
I'm now experienceing the same issue with my system. Even AFTER getting the message about Dforce kernels needing to be compiled and agreeing to same. All I'm getting is the "not responding" message when I try a simulation. :(
