Fatal Error while rendering: ACCESS_VIOLATION (QtGui4.dll)
Brand new PC and Daz 4.12 installation (haven't installed the graphics card yet).
Rendering a scene with default assets, get this error mid-way through rendering:
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\QtGui4.dll" at 0033:00000000613D8AB4, QTransform::type()+4 byte(s)
Searching the forum I found someone with a similar error but their solution was to disable a Windows Defender feature, but such feature is already turned off on my system.
What are your hardware specifications? What GPU driver? Was the render using the GPU(s), the CPU, or some combination?
Happened about 2 times and never again. I suspect it might be related to power management (ie, letting the screen be turned off after a few minutes). So I switched this feature off and did not have the problem anymore. Thank you
