v4 morphs installers
Hi
I really need help my V4 installers no longer work since i switched to windows 8 they worked fine before. I dont use the daz install manager, never installs items right. when i click installer just brings a blank window and does nothing.please help.
DIM installs items just fine if you take the time set the preferences properly. Click on the 'cog' icon in DIM to bring up the preference option. If you are using the old exe installer I would recommend downloading the latest DIM zips. Windows built in zip utility has problems with zips that contain 0Kb sized files so you may want to use one of the many free zip utilities like 7Zip. When installing manually from the zips you want to extract the files and folder inside the "Content" folder not the "Content" folder its self. You will also need to run the bat files that initialize the morphs manually.
