Can i get just the face of the model's head?
i'd like to know if i can get just the front part of the model's head (Vic8 for example), like a mask.
Thanks
  • Yes, though the method - and how useful the result will be - depends on the final aim.
    i just wanted to render a base for painting a mask
  • Just floating in space? You could paint a map on the ehad (in an image editor) that was black on the areas of the ehad you wanted to lose and white elsewhere, then apply that to Cutout Opacity (and probably the Glossy Strength andf some other properties) in the Surfaces pane for the face, hide all the other body parts, make the remaining head areas that are on the torso map fully transparent in the Surfaces pane. Alternatively, if the polygon boundaries were helpful, you could use the Geometry Editor to select the areas you wanted to keep, invert the selection (right-click>Geometry Selection), and delete the selected polygons (right-click>Geometry Editing - actually you can delete unselected polygons too, as I recall, so the invert step coul;d be skipped).
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,510
    you also can pose her through the ground on her back and position the view above
    make sure png and draw dome off
  • LeanaLeana Posts: 13,502
    edited August 2020
    Another option could be using section planes to "cut away" the part of the head you don't want.
    Post edited by Leana on
  • iskander1989iskander1989 Posts: 13
    edited August 2020
    Nice, thanks a lot to everyone, i'll try these. I'd like to have jsut the face floating of course, cause i wanted to render it from behind, i already painted in using other reference, but i'll definitely try those, can be helpful for future projects!
    Post edited by iskander1989 on
  • alan bard newcomeralan bard newcomer Posts: 2,426
    edited September 2020
    Thanks
    turn off all body parts but the head and then cut the opacity on the skinhead to 0
    you can do a lot of "cheating" this way. Was doing some renders with a girl and the falcon and wanted wings.. the same wings the falcon had.
    turn off all falcon parts but wings .. scale up .. stick in model
    1286 x 962 - 265K
    4000 x 2000 - 1M
    Post edited by alan bard newcomer on
  • Thanks too, that's pretty helpful, tried that and it works like a charm for me! Good trick
