Spherical HDR from DS
Doc AcmeDoc Acme Posts: 1,153
edited August 2020 in The Commons
Is there a Camera setting, script, or some other technique where just the Enviro lighting of a scene could be rendered out to a proper spherical HDR format? This for when a Sun/Sky type set up is used.
Post edited by Doc Acme on
  • DripDrip Posts: 1,277
    The camera lens distortion type would have to be set to Spherical.
    The next part is hidden under the advanced tab within your Render Settings. It has a tab within called Canvases, tick the checkbox for Canvases, and add a canvas with the plus sign. The beauty canvas creates a full HDR image of your render, but I'm not entirely sure what the other tabs do. Sickleyield did make a very nice video on some of the canvas features though (I should really watch it again sometime myself to refresh memory).
    But, already just using a spherical lens and the beauty canvas, you can make your own HDRIs, which can be very useful when you have a complex environment that you intend to often reuse with the same lighting and from the same camera position. These two threads should be helpful with that process:
    https://www.daz3d.com/forums/discussion/136101/diy-iray-hdri-using-daz-studio-renders
    https://www.daz3d.com/forums/discussion/397466/creating-hdris-using-daz-assets-cityscapes-etc
  • Doc AcmeDoc Acme Posts: 1,153
    Ah, there it is.
    I've alreasy saved off Sickleyield's tut on Canvases.
    What I'm trying to do is match lighting in a different program.  Using the same HDR works great but I don't have any means of matching the Daz Sun-Sky so thought i'd give this a try.
    Thanks.
