Figures for Figures
davidjones8418
in New Users
Some figures are "for" other figures. I have bought a couple of these in the shop when cheap, intending to buy the figures they are for later (when discounted!).
But do I need them? If I load up Imani for Nida 8, but I don't have Nida 8. But when I load Imani into a scene, there she is.
What am I missing?
If I do need the figures they are for, do I have to load them into a scene irst or something?
they'll load into the scene but they won't look the same, they use the figure they are for as a base morph to various degrees so without the correct 'base figure' you'll just be applying those adjustments to base G8.
The skins/textures should all work fine though
Okay, thanks.
But if I do have the right base figure, do I need to load the base figure and then apply the add-on to it?
Or will Daz work this out?
Generally there will be a character preset, which will load the figure with the shape and materials applied (as far as possible) and shaping/materials presets which can be applied to a pre-loaded copy of the right base figure.
Thank you
