How to edit ligthing of several scenes at once?
Here is the thing: I'm making a comic book, and a lot of scenes take place in the same environment. I want to change the lighting of this environment in one file and have it reflect it in the other 50 scenes that use that environment. Opening each scene and making the same changes over and over is not an option. How can I achieve this result?
  • GordigGordig Posts: 10,798
    What kind of change are you trying to make? You might be able to achieve the same effect with postwork.
    It depends on what kind of lighting your scenes use — actual lights (spot, point and distant), mesh lights (using the Emissive material parameter settings), or Environment lights (either Sun/Sky or using an HDRI). Each of them can be saved as presets to be applied to other scenes, but I don't think it's possible to wrap two or more of them up in a single preset.
  • AscaniaAscania Posts: 1,856
    Then save your lighting setup separately and load it into your scenes.
    Adjust light intensity.
    How can I achieve that for 50 images at once with postwork?
    The camera will be in different position in each scene.
