Missing Files. Textures.
Hi. I'm new. Let me tell you.
I downloaded materials from a website. The first time it worked. Then as I had little disk space, I transferred the material to another. From there I get all the time about the images. I uninstalled the mod, the program and even the contents of the Roaming folder.
This time I have not selected a new path, but the problem remains.
First missing files. Then it says that I must locate the file. If I selecte the correct file, only this file is loaded, the rest don't.
I tried other materials, and the same.
I would appreciate a lot if you could help me.
Thank you very much.
1590 x 856 - 277K
1598 x 860 - 263K
You have not installed correctly - the files that are in the /My Daz 3d Library/Bunny/Content/ folder should be directly in the /My Daz 3d Library/ folder. If you can see the data or Runtime folder in the content Library pane then things are not correctly placed.
