I have a hunch the answer is no but is it possible to parent a prop
comixfana
[I have a hunch the answer is no but is it possible to parent a prop] to two points? I've redone my Bane character this time using the Brute figure, and I've managed to rig a tube going from the left bracer to the back of his head...but that tube needs frequent re-posing and refitting the moment I change his pose, i it possible to parent one end of the tube to the bracer and the other to the back of the head?
692 x 665 - 681K
Post edited by Chohole on
No. You can only parent a prop once. There are some work arounds though.
You can try this:
https://www.daz3d.com/forums/discussion/comment/3782371/#Comment_3782371
I wonder if it's possible to anchor geometry to each other using Rigid Follow Nodes. Just thinking outloud.
That is a cool work around. I would have created a Primitive to the bracer end of the tube and added a IK chain the left bracer & pinned primitive and left the head part parented. that way you can pin/unpin the primitive which will follow the bracer when moving it on the timeline. But this only works if you were using it for animations. But for a still render using deforce is a great idea save a ton of set up time . Thanks for posting that link
