Genesis 8 HD — Add-on
Hello everyone,
I purchased the Alawa 8 HD add-on. It looks great on the photos. https://www.daz3d.com/alawa-8-hd-add-on
BUT I wonder how is it possible to get this beautiful render like in the page of the add-on ?
I import the character, I import the skin material.
But when I go in the surface I don't see any bump map...
The detail on the skin, on the knee or on the hands I dont see them :(
Also ideally I would like to export all those texture (and model) to be able to make the render in C4D.
I have been searching for so long on the tutorials, and on the forum. But I couldn't figure it out.
Maybe there are an expert here that could explain me a quick step by step.
Thank you so much for your help!
For 1.: Select your Alawa figure, open the Parameters tab and type Alawa into the search box. You should see sliders with Alawa in their name. Alawa 8 HD Details is the slider you need to use. (I don't have Alawa 8 HD, but it works like this in other characters)
For 2.: Select your Alawa figure, open the Parameters tab and search for Mesh Resolution settings. Depending on your computer you can set "Render SubD Level (Minimum)" to 4
Also mentioned on the Product Page that in order to see details in real time "(Viewport subdivision must be turned on)."
HD detailing is visible in renders.
