Replicating a view in Scene
avalon0387avalon0387 Posts: 0
I saw a particular scene that I purchased. I want to replicate that exact view, which I liked. Being new to Daz3D, I have no idea how to do it without much trial and error.
.Are there any hidden settings that can give you a viewing angle that was in the promo images?
Thx.
  • ssweetessweete Posts: 115
    What scene is it?
    Did you check the files for cameras?
    Some scene items come with presaved cameras and lights.
  • Richard HaseltineRichard Haseltine Posts: 111,612
    So you have only the rendered image to go by? Check to see if there are DAZ Studio camera presets, or a DAZ Studio scene file with cameras in it, but if not trial and error may be your only option. Which product, and which view were you wanting to match?
  • avalon0387avalon0387 Posts: 0
    It's the La Piazza scene (image attached).
    I really liked one of the angles and lighting. Being new, it takes me practically forever to even find that area in the city – and then to get just the right angle... the learning curve is steep.
    The package says there are camera presets, but I can'r find them in my camera tab.
    Any help would be appreciated.
    499 x 645 - 291K
    edited June 2014
    50 DAZ Studio Camera Presets
    DAZ Studio version comes with 3 light sets based on the bestselling Light Dome PRO 1 / 2
    Light Set Quality - as seen in the promo images
    Light Set Default - approx twice the speed
    Light Set Speed - renders 4-10 times faster
    Your right, look for a folder called camera presets in your content menu.
    255 x 489 - 30K
    Post edited by ssweete on
  • MelanieLMelanieL Posts: 7,874
    edited June 2014
    There are camera presets - in the DAZ Studio Formats section of the Content Library under D2C / AT / Cameras.
    The "AT_Cameras" icon loads 50 different cameras, but unfortunately none of them seems to be the one you are looking for - the closest I found was Camera 37 (see attached screenshot) so you could start with that one, create a new camera with the same settings then manipulate that one with the XYZ-Translate and XYZ-Rotate sliders in the Parameters tab until you get the exact angle you want then save that new camera as a camera preset, if you'd like to keep it for future use.
    ETA: I had a quick play myself and came up with the second screenshot - needs a little more tweaking to get it exactly right but you micht find it a helpful start. Note you will need to change the Focal Length for the camera (in the Parameters tab under "Camera" as well as the XYZ-Translation and XYZ-Rotations - mine's set to 38.40 in this example.
    1417 x 939 - 237K
    1285 x 824 - 158K
    Post edited by MelanieL on
