How do I constrain a middle point in a three point line?
Can anyone tell me how to constraine a middle point to a line between two others?  Picture a v shape, I want to take the bottom point and move it exactly between the other two.  Gotta be a way right?
Thanks.
  • Have 2 lines selected and choose the auto-tessellation option which makes then an evenly spaced line between those 2 lines. Picture an H.
    Then select the unwanted lines and backspace on the keyboard ... do not remove vertices. There should be remaining an evenly placed dot on the one line.
  • AscaniaAscania Posts: 1,856
    Create a line.
    Select line.
    Click Line Tesselation.
    Done.
    Simples.
    Create a line.
    Click Insert Points.
    Hold down SHIFT.
    Click on line.
    Done.
    Simples.
  • FirstBastionFirstBastion Posts: 8,072
    There's usually more than one way to make something you need. I'd use a cube, tesselate1, then select one of those edges, copy/paste generates the 3 point line.  delete cube.
