Help with Animation and Post Denoiser Filter working on only certain frames
I'm really hoping someone can help me understand this issue.
I am rendering out several short animation sequences.  To save rendering time I have set my settings quality off and maximum iterations to 200 iterations per frame. I have set my Post Denoiser to ON with a start iteration of 175.  I render to an image series using .png. The first frame renders as expected.  Denoiser works and looks good enough for animation and my purposes. But then, random frames in the series render without any Post Denoiser... making the series worthless.  I have thought of lowering post denoiser to a start iteration of 100, but worry that it isn't kicking on at all.  Has anyone else run into this?
First Frameimage
3rd Frameimage
652 x 1022 - 129K
645 x 626 - 118K
1296 x 768 - 519K
1296 x 768 - 537K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,491
    is it going to CPU for those frames?
  • That is an interesting possibility. I don't think so though because I think my settings don't allow CPU rendering.
    These are my advanced render settings.
    641 x 965 - 95K
  • OK I have started combing through the log file and it looks like you are correct!  Somehow I am running out of memory on the GPU and it's failing the post denoiser and falling back to CPU (even though it shouldn't according to my settings).  But a few frames later it will work... hmmm.
    try reducing the scene
    remove stuff not in view of the camera,
    reduce texture maps on small objects
    (removing normal and bump maps makes a huge difference and not needed on mouth parts etc if not very close and staying open, presumably if animated mouths would close and open anyway)
  • HTStudiosHTStudios Posts: 41
    edited August 2020
    Will do.  I thought my card was beefy enough to get through a single character with clothes and hair without worrying about such things but apparently not.  Can I just turn off visibility of unseen clothing items (shoes, etc.) or do they need to be deleted to get the benefit?
    Thanks for your help!
    Post edited by HTStudios on
    edited August 2020
    deleting would be better
    adamR clear undo stack script to clear out the unused textures afterwards helps too
    discussion and link here
    https://www.daz3d.com/forums/discussion/17833/removing-unused-textures-ds
  • Thanks again for your help. GPU is doing its job again!
