G2M deformation
JuliKJuliK Posts: 0
Sorry if this is not the correct place ...(and sorry my not so good english)
Somebody help me! Until yesterday everything was ok, but today when I went to use the G2M, these deformations appeared:
http://postimg.org/image/qntb93uqj/
I have no idea what is causing it. It is only with the G2M. Apparently G2F and G1 is OK.
Have reinstalled G2M 2 times and the problem continues.I Increased the subdivision of 1 to 2 ... and nothing.
I cleared the dson cache files and nothing.
Please help!! I'm desperate for a solution.
  • carrie58carrie58 Posts: 4,175
    Is it possible there are some morphs being used ........and actually got saved to the Gen2M ........???Have you checked under currently used???
  • JuliKJuliK Posts: 0
    edited June 2014
    @carrie58, I don´t know. Everything is zeroed, except the "beautiful bends for genesis 2 male" that I believe is automatic.
    And the problem is only on the arms. Legs and everything else is ok.
    What i´ll do now is uninstall Beautiful bends and see what happens. I'm running out of ideas. =(
    Not really sure if this was already happening before, since I had only done simple poses to test a new character I'm doing. Today I was bending his arm and saw the problem.
    Post edited by JuliK on
    Ok, I uninstalled "Beautiful bends" to see if it was causing this, but the problem continues. I do not know what else to do. Even reinstalled daz studio hoping the problem goes away. But the problem continues. =(
    edited June 2014
    The only thing I can think of is to try reinstalling the Gen2M ,fresh,maybe some how the one you've got ,got messed up ....wish I could be more help.
    and I mean before you reinstall the beautiful bends ,try reinstalling Gen2M .........
    Post edited by carrie58 on
    edited June 2014
    @carrie58, thanks for trying to help me anyway.
    That is exactly what I´ll do now. I tried to avoid, but apparently i'll have to do that. I´ll have to reinstall Gen2M again , fresh, as you said. And then I´ll reinstall all of his morphs.
    I hope this solve the problem. =/
    Looks like a JCM is firing when it should not. Does it happen when the arms are bent?
    Show the hidden parameters and check what JCMs are being used. This happened the last time to me when Boris was installed, but should be fixed now.
    @Male-M3dia, I´ll try tomorrow. It´s too late here and my head is hurting. :(
    What is JCM? Sorry my ignorance. :red:
    I have Boris. If is the same problem you had, I still have to reinstall everything? Or it´s something simple to fix? *praying*
    I have to sleep now. Thank you for your reply, Male-M3dia!
    Tomorrow i´ll see if the JCM is the problem and i´ll back here to say something. :)
  • Richard HaseltineRichard Haseltine Posts: 111,715
    A JCM is a joint-controlled morph - a morph that is set not by a slider available to the user but in response to the bending of a joint. JCMs are generally used to adjust the mesh to improve the look of it when posed - which is what the Beautiful Bends products do, for example.
    Thanks for the information, @Richard! :)
    I think it´s not "Beautiful Bends", because I already uninstalled and the problem continues.
    @Male-M3dia, Yes, the problem is only when I bend the arms and move the shoulders (like in the image below)
    But , following your suggestion, I went to look at the JCM hidden parameter and saw that Boris was the only one who was not zeroed and exactly in the arm and shoulder that are posed. Exactly where the problem is happening.
    Maybe that's my problem? What do I do now?
    Images:
    http://s30.postimg.org/tmwwhdgnl/gah2.png
    http://s30.postimg.org/57oogbhqp/gah3.png
  • Zev0Zev0 Posts: 7,123
    edited June 2014
    Looks like Boris JCM's is the problem, but that is strange as I have Boris and on base shape the JCM's do not dial when anything is bent. They only dial when I have Boris shape dialed in.
    Post edited by Zev0 on
    And what i should do now? What do you guys suggest?
    I'm almost deleting Boris (to reinstall later) Is there a way to fix this without reinstall anything?
    edited June 2014
    You should have received an DIM update to Boris that corrected this. I think the fix was rolled out a month ago or more. Smay was very responsive to fix this. Reinstall Boris, or manually find the JCM file and delete it.
    Post edited by Male-M3dia on
    Thanks, Male-M3dia! I didn't know!
    Hope this solve the problem! *crossing fingers*
    I don´t use DIM, so I´ll download the file again. :)
    Ha !! I knew somebody smarter then me would pop in and help you figure it out!!
