Deleting Unwanted Files From Downloads
I'm going to use the wrong words here because I'm not sure how to explain this, but it's my understanding that when you purchase and download a product from Daz, there is some sort of file (Zip?) that is downloaded and not needed. Where can I find these files so I can delete them? I need the disk space. Thanks
  • kenshaw011267kenshaw011267 Posts: 3,805
    edited August 2020
    It's set inside DIM.  You can also tell DIM to delete the packages once installed so you don't need to do this housekeeping again.
    Adavnced settings -> Package Archive
    Post edited by kenshaw011267 on
    Note that what's placed in that folder is actually a pair of files — the .zip is the actual archived content files, and can be safely deleted after installation, but the matching and much smaller files (I think it's a .dsx extension) are used by DIM. If you delete these files, DIM will want to re-download and re-install everything again, and it won't be able to tell when something's been updated.
    edited August 2020
    No, it's the .dsx files in the ManifestFiles folder that mustn't be deleted.  The .dsx files in the Downloads folder can be deleted long with the .zips
    Post edited by fixmypcmike on
    <headdesk> Thanks, Mike, I always get those two mixed up.
    @mwokee "there is some sort of file (Zip?) that is downloaded and not needed"
    The .zip file contains your content. Don't delete it until after installation.
